Java_man
Jun 28, 2022Aspirant
R7000 DHCP question
I checked my R7000 log this morning and saw this: "[LAN access from remote] from 192.144.226.157:26559 to 192.168.1.2:80, Tuesday, Jun 28,2022 03:33:38" Reading through the logs I see multiple e...
Jun 28, 2022Guru - Experienced User
Do a who is lookup on 192.144.226.157
What FW version is currently loaded?
Java_man
Thanks for the reply.
Netgear FW: V1.0.9.88_10.2.88
I looked up a couple of the IPs and they were an ISP in England - pptechnology.
Modem: Motorola Surfboard SB6120 connected to Comcast.
Also noticed they're all connecting to 192.168.1.2:80 (port 80 - the HTTP port).
- FURRYe38Jun 28, 2022Guru - Experienced User
What devices has the address 192.168.1.2?
- Java_manJun 28, 2022Aspirant
That's just it. . . none of them. I pinged the address and get no reply messages.
It's not listed in my "Connected Devices" page in the Netgear software either.
Pinging 192.168.1.2 with 32 bytes of data
Reply from 192.168.1.100: Destination host unreachable.
Reply from 192.168.1.100: Destination host unreachable.Ping statistics for 192.168.1.2:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),- FURRYe38Jun 28, 2022Guru - Experienced User
I would do this, turn OFF all devices accept for 1 wired PC. Change the Default DHCP IP address pool range as suggested.
After you apply the change and the router reboot. Power OFF the ISP modem and router for 1 minute then back ON.
I would leave all devices off accept for the 1 wired PC.
Check the connected devices page on the router. You PC should be listed here.
If it is, turn on 1 device. Let it connect, check the connected devices list again. If seen, check the log page for any LAN access entries.
Graduate turning on devices one at a time and check the connected devices page. Take not of any device that doesn't appear on the page.
Check the log for any continue LAN access entries.
