Java_man
Jun 28, 2022Aspirant
R7000 DHCP question
I checked my R7000 log this morning and saw this: "[LAN access from remote] from 192.144.226.157:26559 to 192.168.1.2:80, Tuesday, Jun 28,2022 03:33:38" Reading through the logs I see multiple e...
Jun 28, 2022Guru - Experienced User
What devices has the address 192.168.1.2?
Java_man
Pinging 192.168.1.2 with 32 bytes of data
Reply from 192.168.1.100: Destination host unreachable.
Ping statistics for 192.168.1.2:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
- FURRYe38Jun 28, 2022Guru - Experienced User
I would do this, turn OFF all devices accept for 1 wired PC. Change the Default DHCP IP address pool range as suggested.
After you apply the change and the router reboot. Power OFF the ISP modem and router for 1 minute then back ON.
I would leave all devices off accept for the 1 wired PC.
Check the connected devices page on the router. You PC should be listed here.
If it is, turn on 1 device. Let it connect, check the connected devices list again. If seen, check the log page for any LAN access entries.
Graduate turning on devices one at a time and check the connected devices page. Take not of any device that doesn't appear on the page.
Check the log for any continue LAN access entries.
