Java_man
Jun 28, 2022Aspirant
R7000 DHCP question
I checked my R7000 log this morning and saw this: "[LAN access from remote] from 192.144.226.157:26559 to 192.168.1.2:80, Tuesday, Jun 28,2022 03:33:38" Reading through the logs I see multiple e...
Jun 28, 2022Guru - Experienced User
Would be curious to see what happens if you set the default DHCP IP address range to 192.168.1.100 to.200.
Has a factory reset and setup from scratch been performed since you updated FW?
Something would be using .2 I believe. What browser are you using? Try MS Edge or Firefox and see what's seen in Connected Devices.
Java_man
Earlier today I reset DHCP to begin range with 192.168.1.3.
I cleared the logs and will post when there are some entries.
[LAN access from remote] from 163.172.158.4:57501 to 192.168.1.2:80, Tuesday, Jun 28,2022 10:02:50
BUT, I just remembered I used to host a web server. I searched some code that checked on the IP of the server and it was 192.168.1.2. Took it offline years ago and it's not even connected.
Thoughts?
