lordbah
Jan 02, 2023Tutor
R7000 died?
R7000 working fine for years. This morning all LAN LEDs are dark and Ethernet devices can't reach anywhere. Wireless devices say they can connect to the router but the router has no internet connecti...
microchip8
Jan 02, 2023Master
Do you have auto-update enabled? If so, it might have bricked your router.
Have you tried a TFTP recovery? https://kb.netgear.com/000059633/How-do-I-upload-firmware-to-my-NETGEAR-router-using-a-TFTP-client-on-Microsoft-Windows
- lordbahJan 02, 2023Tutor
I don't think I had auto-update enabled, not entirely sure.
Windows isn't allowed in my house, but I'm sure I can find tftpd for Linux and try that. I'm dubious it'll work since the laptop thinks the cable is unplugged. Will let you know.
- FURRYe38Jan 02, 2023Guru - Experienced User
If you can get a new power adapter, try that first.
If after the power adapter doesn't resolve this, try a 30-30-30 reset on the router. Might kick it out of it's bad state. If that or TFTP even fails, then the router just may be bad and needs replacing.- microchip8Jan 02, 2023Master30-30-30 reset doesn't work on ARM-based routers. Only MIPS ones.
