MHCLV941
Nov 03, 2021Aspirant
R7000 Disable Anywhere Access in Web Interface/Remote Management??
How do I disable (or even check the status) of "Anywhere Access" via the router's web interface. I dislike using apps and don't want to waste my time setting it up just to change one setting. I ...
Nov 03, 2021Guru - Experienced User
There mabe a slider button under Advanced Tab/Adanced Settings/Web Management Service?
I have seen references to "Remote Managemnt" which I also want to disable. However, various articles say that this is a setting in Advanced Setup, but I cannot find it. Was it replaced by "Anywhere Access"?
R7000/AC1900, firmware v.1.0.11.128_10.2.112 (Current as of this writing).
MHCLV941
Thanks but no joy. There is not even an item "Web Management Service" on the web interface.
