mkonstantin
Jul 21, 2019Guide
R7000 DLNA Enable Option
Hi all,
Perhaps you someone could point me at location of Enable/Disable DLNA server option in latest "V1.0.9.88" revision of firmware of R7000 (AC1900) Nighthals Router. I recall that some of the ...
- Jul 23, 2019
mkonstantin, I didn't miss the point. I don't have an active R7000 so I can't tell if it is there or not?
It wouldn't surprise me if NG messed it up. Like the screen shot I posted the removed items were on that page. Some probably untrained programmer removed the function and the web page to enable it. Probably was CLUELESS as to what DLNA was so removed the whole page. Code is probably still in the f/w, but no way to enable it.
All I can say complaining here and HOPING NG people report this back and get it fixed is a crap shoot.
DarrenMcan you get this fixed as soon as possible?
Your fix for now, go back to V1.0.9.42 I'd think, .60, .64, and .88 all have serious problems for many user's in varying ways.
IrvSp
Jul 25, 2019Master
mkonstantin wrote:
Here is current workaround:
1. Rollback to lats verison of firmaware supporting it
2. Rebuild ReadySHARE sqllite database and keep MediaServer enabled
3. Upgrade to actually latest version of firwmare
and this workaround sucks!
See the first post on the next page by thevines. Your work-around was tried and didn't work? Wonder why it worked for you and not him? Maybe there was something else that had to be done? Different OS version or using a different browser?
Odd that it worked for you and not that user?
mkonstantin
Jul 29, 2019Guide
I must be a lucky one :-)
I was out for some time so had to time to test statud of DLNA engine after recovery with .42 and later repaved with .88 but i may try tonight
