Mach1ray's avatar
Nov 30, 2016
R7000 doesnt meet half of what my wifi spwed should be.
Ive changed channels, upgrades QoS, eliminated wifi from base modem/router and nothing. Of the 50 mbs Im suppposed to see, I only get, if lucky 20. At an average, I see 10. Are there otuer tweaks I ca...
  • IrvSp's avatar
    IrvSp
    Nov 30, 2016
    Mach1ray wrote:
    Sorry, responded too soon. Router is not connecting to the modem. Nor the internet for that matter. The router is hard wired to the modem
    If you've been changing the attached device (router or PC) that connects to the modem you'll have a problem connecting as the modem is looking for a specific MAC Address.
    Here is what you need to do:
    • POWER all PC's, the ROUTER, and the MODEM OFF
    • Next power ON the MODEM and wait for it to come on line (lights all basically on, but some might flash), a few minuted maybe depending on the modem.
    • Next power ON the router and wait for it to fully come up, again, a few minutes.
    • Next the PC and all the wireless to connect, the wired ones will automatically.
    That should fix it.
