Mach1ray
Nov 30, 2016Tutor
R7000 doesnt meet half of what my wifi spwed should be.
Ive changed channels, upgrades QoS, eliminated wifi from base modem/router and nothing. Of the 50 mbs Im suppposed to see, I only get, if lucky 20. At an average, I see 10. Are there otuer tweaks I ca...
- Nov 30, 2016
Mach1ray wrote:Sorry, responded too soon. Router is not connecting to the modem. Nor the internet for that matter. The router is hard wired to the modem
If you've been changing the attached device (router or PC) that connects to the modem you'll have a problem connecting as the modem is looking for a specific MAC Address.
Here is what you need to do:
- POWER all PC's, the ROUTER, and the MODEM OFF
- Next power ON the MODEM and wait for it to come on line (lights all basically on, but some might flash), a few minuted maybe depending on the modem.
- Next power ON the router and wait for it to fully come up, again, a few minutes.
- Next the PC and all the wireless to connect, the wired ones will automatically.
That should fix it.
IrvSp
Nov 30, 2016Master
What MODE is the router in may I ask? Advanced Tab, Advanced Setup, Router / AP / Bridge / Repeating Mode shows what mode you are in, possibly AP?
The modem should be in BRIDGED mode and then connected to the Router which serves the wired and wireless devices. If the modem can produce wireless signals it is not in Bridged mode. However I don't think this matters.
What IS the error message?
Open a COMMAND PROMPT and enter IPCONFIG /ALL and paste in the Ethernet section please, it should look like this:
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : F8-B1-56-DD-7F-AA
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::58bf:9e27:bf45:87e8%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.30(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, November 30, 2016 5:57:18 PM
Lease Expires . . . . . . . . . . : Thursday, December 1, 2016 5:57:18 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 49852766
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-04-98-17-F8-B1-56-DD-7A-AA
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Lines in RED are the important ones.
Mach1ray
Nov 30, 2016Tutor
I really appreciate you all jumping in here to help. BTW, some how I lost my private network and now on a public one. This is all driving me crazy. Just a newbie, please bear with me. Here are the details you requested.
Windows IP Configuration
Host Name . . . . . . . . . . . . : ElLatino-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : fios-router.home
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : fios-router.home
Description . . . . . . . . . . . : Intel(R) 82567V-2 Gigabit Network Connection
Physical Address. . . . . . . . . : 90-E6-BA-32-50-91
Link-local IPv6 Address . . . . . : fe80::6195:4c60:6a5c:2884%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.164(Preferred)
Lease Obtained. . . . . . . . . . : Wednesday, November 30, 2016 6:12:34 PM
Lease Expires . . . . . . . . . . : Thursday, December 01, 2016 6:12:33 PM
DHCPv6 IAID . . . . . . . . . . . : 244377274
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-3E-D9-A6-90-E6-BA-32-50-91
Wireless LAN adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 00-22-5F-EF-35-86
Wireless LAN adapter Local Area Connection* 3:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : 00-22-5F-EF-35-85
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : 802.11n Wireless PCI Express Card LAN Adapter
Physical Address. . . . . . . . . : 00-22-5F-EF-35-84
Ethernet adapter Bluetooth Network Connection 2:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) #2
Physical Address. . . . . . . . . : 5C-F3-70-78-22-C0
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:d5d:a599:3cd6:30f5:d03a:eaef(Preferred)
Link-local IPv6 Address . . . . . : fe80::3cd6:30f5:d03a:eaef%5(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 570425344
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.fios-router.home:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
C:\Users\El Latino>
When I try to log on to the router page, I get a "bad request" error message. Host name invalid. Netgear model # a1900/R7000
- Mach1rayNov 30, 2016Tutor
I failed to mention the r7000 is NOT connecting to the modem/router
- IrvSpNov 30, 2016Master
Mach1ray wrote:I failed to mention the r7000 is NOT connecting to the modem/router
Not connecting as in you have NO Internet or there is no wire between the modem and router?
I wondering about this line, "IPv4 Address. . . . . . . . . . . : 192.168.1.164(Preferred)"? Why is the PC IP Address that? Not normal unless YOU (or whoever set up the LAN) has preset that address? Either via the Network Adapter Properties or on the Router by MAC Address as a reserved address?
What are you using to try and reach the router's homepage? What browser? What are you entering in the URL?
I'm using Intgernet Explorer and signing on with www.routerlogin.net. The R7000 is now showing in my list of available wifi connections as netgear93 and when I sign on to that one using the passwoard provided with the router it connects, brings up IE but connects to MSN.com, not the router page. In the Network and Sharing page, it shows up there as a private network, but, not connected to the internet. On the same page, I was able to change the mysterious public network to a private one, but, its name is not what I had originally.
