Psychbum
Apr 20, 2022Star
R7000 DoS attacks help please
Not sure why but in my router logs I am seeing the following; [DoS attack: Smurf] then an IP address which is the IP of my iPhone 13 pro max. Anybody know what is causing this, it happens a f...
Apr 20, 2022Guru - Experienced User
Netgear R7000 is notorious for false positives on the DoS attacks.
You can check the ip of the address if you'd like.
Is it impacting performance?
I'd do a quick search through the forums for more info on the potential false positives.
- PsychbumApr 20, 2022StarThe IP address is the one of my iPhone, so 182.168.1.12 which is not coming from outside but from inside I believe.
Is that correct?- plemansApr 20, 2022Guru - Experienced User
if its coming from your iphone, i'd look at it as a false positive.
You might try disabling random mac/ip address on the iphone and see if that helps.
Again, try a quick search on the forums
