Psychbum
Apr 20, 2022Star
R7000 DoS attacks help please
Not sure why but in my router logs I am seeing the following; [DoS attack: Smurf] then an IP address which is the IP of my iPhone 13 pro max. Anybody know what is causing this, it happens a f...
Apr 20, 2022Guru - Experienced User
Netgear R7000 is notorious for false positives on the DoS attacks.
You can check the ip of the address if you'd like.
Is it impacting performance?
I'd do a quick search through the forums for more info on the potential false positives.
Psychbum
Apr 20, 2022Star
The IP address is the one of my iPhone, so 182.168.1.12 which is not coming from outside but from inside I believe.
Is that correct?
Is that correct?
- plemansApr 20, 2022Guru - Experienced User
if its coming from your iphone, i'd look at it as a false positive.
You might try disabling random mac/ip address on the iphone and see if that helps.
Again, try a quick search on the forums
