Psychbum
Apr 20, 2022Star
R7000 DoS attacks help please
Not sure why but in my router logs I am seeing the following; [DoS attack: Smurf] then an IP address which is the IP of my iPhone 13 pro max. Anybody know what is causing this, it happens a f...
Psychbum
Apr 20, 2022Star
The IP address is the one of my iPhone, so 182.168.1.12 which is not coming from outside but from inside I believe.
Is that correct?
Is that correct?
Apr 20, 2022Guru - Experienced User
if its coming from your iphone, i'd look at it as a false positive.
You might try disabling random mac/ip address on the iphone and see if that helps.
Again, try a quick search on the forums
