Psychbum
Apr 20, 2022Star
R7000 DoS attacks help please
Not sure why but in my router logs I am seeing the following; [DoS attack: Smurf] then an IP address which is the IP of my iPhone 13 pro max. Anybody know what is causing this, it happens a f...
Boris-R7000Bg
May 28, 2022Tutor
Hello! I have a problem with my R7000 route! My router started to restart constantly for 1 hour, it restarts at least 12 times and so my internet is interrupted, can anyone help me and tell me how I can solve this problem! Thanks
May 28, 2022Guru - Experienced User
Boris-R7000Bg please stick to your post. keeps your info from getting confused with the OP's.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000/m-p/2227766#M216443
thanks
