dwhiting1985
Sep 10, 2021Guide
R7000 Download speed on Gigabyte Internet
I have the Nighthawk R7000 AC1900. I had had this router for years, always worked great. I am on the firmware V1.0.6.28_1.1.83 I havent updated becasuse i didnt want to lose Arlo support. Also I ...
Sep 10, 2021Guru - Experienced User
What modem do you have?
And what server are you speedtesting on? Thats kind of key as not all test servers can fully saturate gigabit connections.
Who's your isp? usually they have a test site you can test your speeds off that will get closer to saturating gigabit.
You can always save a backup configuraiton of your router and update it. If yours happens to have issues, you can always downgrade back down.
