dwhiting1985
Sep 10, 2021Guide
R7000 Download speed on Gigabyte Internet
I have the Nighthawk R7000 AC1900. I had had this router for years, always worked great. I am on the firmware V1.0.6.28_1.1.83 I havent updated becasuse i didnt want to lose Arlo support. Also I ...
Sep 10, 2021Guru - Experienced User
You went in and set it to disable router functions (turning off wifi doesn't disable routing functions)?
How did you do this?
Are you able to connect more than 1 device to it and have both function?
dwhiting1985
Sep 10, 2021Guide
correct, modem only mode.
- plemansSep 10, 2021Guru - Experienced User
And if you test directly connected to it with a pc/laptop do you get full speeds throughout the test?
- dwhiting1985Sep 10, 2021Guide
i stated that in my first post, yes, if i put the modem back into router mode, connect my PC to the modem directly, yes i get about 980Mb or so.
to answer your question, yes I get the full speed on the modem, when its connected to my router and the modem is switched to modem only mode, thats when the problem starts.
I have no QoS on, and no access control or anything like that, and also no network traffic on either for tracking it. I heard before that having the traffic meter on can cause problems, thats off as well.
Might be worth trying the update then
