dwhiting1985
Sep 10, 2021Guide
R7000 Download speed on Gigabyte Internet
I have the Nighthawk R7000 AC1900. I had had this router for years, always worked great. I am on the firmware V1.0.6.28_1.1.83 I havent updated becasuse i didnt want to lose Arlo support. Also I ...
Sep 10, 2021Guru - Experienced User
Have you powered OFF both ISP modem and router for 1 minute then back ON. Factory reset the router and setup from scratch. Don't enable any Armor, Traffic Meter or Access Controls and run a speed test from a wired PC soon after the router is set up?
dwhiting1985
Sep 10, 2021Guide
"Re: R7000 Download speed on Gigabyte Internet
Have you powered OFF both ISP modem and router for 1 minute then back ON. Factory reset the router and setup from scratch. Don't enable any Armor, Traffic Meter or Access Controls and run a speed test from a wired PC soon after the router is set up? "
Yes I have done the above, first thing I thought of doing.
I have also tried
different network cable
different PC
different network adapter (My Asus has 2 with Intel and killer ethernet 2.5Gbps port)
all the same result
- FURRYe38Sep 10, 2021Guru - Experienced User
What is the results if you use the ISP modem in router mode and configure the router for AP mode?
- dwhiting1985Sep 10, 2021Guide
max speed, got around 980Mb steady, no hiccups or stutters.
Possible that in router mode, the Cut-Thru or HW accelleration is not working...This is not need while in AP mode so why speeds are good in AP mode.
