DamagedDingo's avatar
DamagedDingo
R7000 drop outs and slow wifi - Firmware
I found this post that says to use Firmware version 1.0.9.42 but I was only getting 25mb via wifi (Australia)
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Dropping-WIFI-Daily/m-p/1994286/highlight/true#M171468
I have now downgraded through all the versions and tried different channels and the newest one that works is V1.0.9.32.
Your milage might vary but I wanted to let people know as it took me days to get through all the testing to find something stable and fast again.
I'm honestly not sure why all the latest firmware sucks so much but I will defiantly not be buying one of these again.
  • DamagedDingo  Well you have more patience than most! Depending on where in the world you happen to be, the effects of the multitude of firmwares Netgear has released for this product, can seemingly vary from user experience. This forum is littered with hundreds of posts about the R7000 firmware. I can assure you, there are far more capable home routers out there. It just depends if you want to spend the money or trust your ISP to come up with a home router solution that works. I took the plunge and bought a bang up to date tri-band router and I've not had a single issue with it. You'd really have to ask the firmware boffins who keep pushing out multiple releases for this router why their firmware is causing problems. The fact they release so many firmware updates is enough to set alarm bells ringing anyway, especially if they cause more issues than they solve. The R7000 is a decade old concept and it shows.
    • DamagedDingo's avatar
      DamagedDingo
      It’s not a bad router if you stick to old firmware. It’s a old device now so my guess is they just don’t care. It’s been getting worse and worse for over a year until finally it just couldn’t hold a wifi connection. I was going to buy new one but thought I’d confirm it’s not software and was going to try 3rd party software but there is none compatible. The post I linked is top result on google which is why I made an account to give my findings because only way to prove it was hardware was to go back through all the firmwares. Funny thing is that is from 2018 and 2 years ago my device was fine and was on auto update. So that bit I can’t figure out.
      Btw I have no patience at all, just broke.. I feel sorry for my neighbours who herd cursing for weeks.
      • Portwey84's avatar
        Portwey84
        Virtuoso
        DamagedDingo  And you summed it up in one, it's an old device. I found that even after just 2 years of use from buying new, I had something like 11 firmware updates, most of which to be fair I had no issues with, until v.128 which wrecked my WiFi. I then had a massive issue in that my WiFi6 enabled desktop PC would completely wipe out the R7000 5ghz band destroying my Wife's internet connection. We for a while had to resort to hardwiring her work laptop just so she could work but trailing an ethernet cable halfway round the house, was just not acceptable. In short, the R7000 was just no longer up to the job on my fully fibre network. My replacement AX router is doing exactly what it's supposed to.
