bwhittemore95
Jul 09, 2020Tutor
R7000 Dropping 2.4Ghz Constantly
 With the recent move to home, my partner and I have been relying increasingly on our internet. We've noticed more and more drop-outs from the router that have been making working from home and doing ...
- Jul 09, 2020
> [...] I tried to search for a firmware update, but it said there
> weren't any updates available."search" how? "it"?
And your web/forum search for terms like, say:
R7000 firmware
found nothing interesting?> Firmware Version: V1.0.9.88_10.2.88
Not the latest; probably not the best.
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
antinode
Jul 09, 2020Guru
"search" how? "it"?
      R7000  firmware
instructions.
bwhittemore95
Jul 09, 2020Tutor
antinode wrote:> [...] I tried to search for a firmware update, but it said there
"search" how? "it"?
Apologies - I should have specified. I went on the Nighthawk App and used the "Check For Updates" tool. I recalled seeing that a newer firmware was available, which is why I was surprised when it didn't pop up in the results.
I'll follow the instructions you provided this evening to see if it helps. I really appreciate the input.
- plemansJul 09, 2020Guru - Experienced User
Many have issues with the R7000.
Many find success using the 1.0.9.42 version of the firmware. You can try that version, factory reset the router, and reinstall it. See how it performs.
