rpzky8
Apr 22, 2020Guide
R7000 dropping 5Ghz randomly
I was transitioned to work from home so I was able to finally notice this, but my 5Ghz connection on my router occasionally drops. During the course of my 9-10 hour shift, the connection drops around...
- Apr 22, 2020
the general agreed upon decent firmware for the R7000 is 1.0.9.42.
the recently released version is still waiting feedback but the initial results aren't any better from what I've seen.
What modem is it from xfinity?
Try installing that firmware, factory reset again, and make sure to manually install.
DragonWarrior
Jun 08, 2020Tutor
Same issue. I've had the router for years. Its on auto update for firmware and at some point after a firmware update I have unstable 5ghz network. This is a huge issue and a real disappointment with this router after years of stable operation. Hopefully they put out another update to correct the issue. I wouldn't expect support on an old router like this except that it is still sold new instores.
Portwey84
Jun 08, 2020Virtuoso
DragonWarrior I totally accept that to some of the contributors here that I am probably starting to sound like a broken record, but I'm still not having any issues whatsoever with the very latest firmware and I've been running it for 2 months now, no WiFi drops on either 2.4 or 5ghz.
I have made some 'tweaks' from default but nothing other than what I've already publicly posted. I did make one further tweak the other day, I now use my own preferred NTP server localised to my Region. I have no idea what the default NTP server is that Netgear use?
