rpzky8
Apr 22, 2020Guide
R7000 dropping 5Ghz randomly
I was transitioned to work from home so I was able to finally notice this, but my 5Ghz connection on my router occasionally drops. During the course of my 9-10 hour shift, the connection drops around...
- Apr 22, 2020
the general agreed upon decent firmware for the R7000 is 1.0.9.42.
the recently released version is still waiting feedback but the initial results aren't any better from what I've seen.
What modem is it from xfinity?
Try installing that firmware, factory reset again, and make sure to manually install.
TOOMUCHSAUCE
Jul 07, 2020Apprentice
spcrick wrote:
Try updating to 11.104... i’ve been using for 48 hrs and its still strong. Havent had any drop connections so far.
This did not work for me.:smileysad: Can tell quickly if I open twitter on an ipad. Images don't load or take long loading and the connectivity icon has the spinning asterisk constantly like it's hunting for a good connection. Didn't bother waiting for the full drops.
Back to .42
spcrick
It got my hopes up sigh... after about 72 hrs of stable connection, the router decided to restart itself for no reason. Back to .42 for me too sigh.
- lkuhnJul 09, 2020Guide
I hope I'm not going to jinx myself by typing the words, but I've been on https://kb.netgear.com/000062033/R7000-Firmware-Version-1-0-11-104-Hot-Fix for 3 fully active work days (currently in the 73rd hour since reboot) and the 5Ghz network (as well as the 2.4Ghz) has been completely stable.
Continuing to knock wood and keep things crossed.
