rpzky8
Apr 22, 2020Guide
R7000 dropping 5Ghz randomly
I was transitioned to work from home so I was able to finally notice this, but my 5Ghz connection on my router occasionally drops. During the course of my 9-10 hour shift, the connection drops around...
- Apr 22, 2020
the general agreed upon decent firmware for the R7000 is 1.0.9.42.
the recently released version is still waiting feedback but the initial results aren't any better from what I've seen.
What modem is it from xfinity?
Try installing that firmware, factory reset again, and make sure to manually install.
DragonWarrior
Jul 30, 2020Tutor
104 wasn't stable for me for the 5ghz. I finally thru in the towel on this one and got a TP-Link AX6000 router. No issues with wifi now.
- larcielAug 09, 2020Guide
I had same issue and I remember that I had to downgrade my firmware few years ago so same stability issue.
Can't believe Netgear cannot get a right FW after .42 which was released in 2018???
Going to trash this router and buy a different company router. Frankly, this router served well for last 4 years, but it's showing signs of going down.
- BinkieAug 10, 2020InitiateI installed the 106 version yesterday but this did unfortunately not solve my problems with the network drops. This is very frustrating especially now I have to work from home because of covid. Very strange that a big company like Netgear is not able to solve the problems. Hopefully it will be solved soon and otherwise I have to search for another real quality router.
- spcrickAug 10, 2020Apprentice
I gave up on any version past .42... I also didn't wanted to be stuck on an old version with security flaws so I ended up buying a new router. I got an Asus RT-AX88U and so far it's pretty good.
