rpzky8
Apr 22, 2020Guide
R7000 dropping 5Ghz randomly
I was transitioned to work from home so I was able to finally notice this, but my 5Ghz connection on my router occasionally drops. During the course of my 9-10 hour shift, the connection drops around...
- Apr 22, 2020
the general agreed upon decent firmware for the R7000 is 1.0.9.42.
the recently released version is still waiting feedback but the initial results aren't any better from what I've seen.
What modem is it from xfinity?
Try installing that firmware, factory reset again, and make sure to manually install.
TOOMUCHSAUCE
Aug 15, 2020Apprentice
Well I gave in and bought a new router. It's the Linksys MR9000 Max-Stream AC3000 tri-band. The router is currently on sale at Best Buy for $150 (normally $250), less than what a new r7000 costs!
I did extensive testing and it offers:
1) At long range, further and much faster 2.4ghz throughput
2) At long range, slightly further and slightly faster 5ghz throughput
3) At close or medium range, MUCH faster 2.4 and 5ghz throughput
4) 100% stability, NO DROPS!!!
This is in a 2200 sq foot house and the long range was downstairs one side to upstairs other side. The r7000 5ghz was unusable at this range while the Linksys was completely serviceable (although I still chose the 2.4ghz as it had a better connection with comprable speeds at that range.)
If $150 is in your budget and you are looking for a replacement that is better in every way... this is a great choice!!!
Mike
CharlieS1900
Aug 18, 2020Initiate
Thanks for sharing the information on Linksys MR9000/AC3000. I checked the Bestbuy website but found the price of MR9000 went back to $250. Will monitor the price and get one.
Only the .42 version of the FW has worked so far. The latest .106 worked for a day but then dropped 5g for about 15 minutes the second day; and thus back to .42 again.
- spcrickAug 18, 2020ApprenticeI moved on from the r7000 after 6 years.. i’m not sure if linksys routers are still good. The last one i owned was the wrt54g. I ended up getting an Asus rt-ax88u. Even though its a bit on the pricey side but the range did improve a lot. I used an ex7300 range extender with my r7000 to get stable connection towards the back of the house before.. now the rt-ax88u reaches the back of the house without ang extenders.
- TOOMUCHSAUCEAug 24, 2020Apprentice
spcrick wrote:
I moved on from the r7000 after 6 years.. i’m not sure if linksys routers are still good. The last one i owned was the wrt54g. I ended up getting an Asus rt-ax88u. Even though its a bit on the pricey side but the range did improve a lot. I used an ex7300 range extender with my r7000 to get stable connection towards the back of the house before.. now the rt-ax88u reaches the back of the house without ang extenders.I like this router a lot but at 350 it's pricey. I just needed something as good as the r7000 at my mom's hourse and for me the $150 MR9000 was perfect! For my house I would consider the rt-ax88u but I've been burned buying future-proof routers like the (somewhat glitchy) xr700 I currently own. For one, because of the price tag not a lot of people bought it so they don't support it that much -- a major lesson learned. And while it has the 60hz band which offers incredible speeds, I only have one device (a new macbook air) that can take advantage of it. I learned that stuff changes so fast on these routers that by the time the majority of your devices can support the new features (like wi-fi 6) there will a be much better and cheaper router available -- so I will only buy what I need from now on. If I have to replace the xr700 I would just get the best (combo of price, speed, distance, support) wi-fi 5 router and call it a day, saving my pennies for my next router in 3-4 years.
- spcrickAug 24, 2020ApprenticeI understand your concern.. i was debating between the asus or a newer netgear also. But i ultimately decided on asus because a lot of people highly recommended the RMerlin custom firmware for the RT-AX88U. I checked out Rmerlins firmware and it looks like he is still supporting the older asus models as well. i also checked out asus website and they also support their older routers unlike netgear. Netgear took almost a year to come out with a newer fw btw .88 and .104. I think they released something in btw but it bricked some ppls routers that they pulled it. I didnt want to get another netgear that ended up like the r7000.
CharlieS1900 wrote:Thanks for sharing the information on Linksys MR9000/AC3000. I checked the Bestbuy website but found the price of MR9000 went back to $250. Will monitor the price and get one.
It looks like it's back in stock and for $150 again at Best Buy!!!
- apara223Aug 24, 2020Guide
In summary, I actually had an older R7000 which worked fine and a year ago I purchased another R7000 which did not work well. My original, older R7000 is running on the latest firmware without any issues. The newer R7000 has been deprecated due to dropping 5Ghz connections and replaced with Asus AC5300 which is working fine.
I have no idea how to identify the differences between these two models as the label does not appear to show any obvious version number. Both devices were made in Vietnam.
- CharlieS1900Aug 24, 2020InitiateThanks for the information on Best Buy.
- spcrickAug 24, 2020ApprenticeI dont know how i feel about linksys. The last one i owned was a e2500. Either their routers are that good that doesnt need frequent firmware updates or their support is just so bad they can only push out a fw every blue moon. Some of them they literally just stopped supporting.
