AdeUK
Sep 29, 2021Follower
R7000 dropping 5ghz
Hi all,
I reported the above fault to Netgear before happening upon the firmware downgrade fix within these forums.
My case has escalated and is being passed to a 'second level technician' - although I'm not sure what this means, I am hoping it raises the issue with netgear and they can resolve.
FYI my router was manufactured March 2021 and the latest firmware caused this issue for me.
I will update you if resolved.
- Portwey84Virtuoso
AdeUK Well, this believe it or not, is a post I thought I'd never have to make, but it seems the latest firmware version, 1.0.11.128 is indeed, borked on the 5ghz WiFi. I've been monitoring my router for the last 3 days and every time I connected my desktop, it dropped out all of my other devices on 5ghz. It caused a right old ruck with my Missus who's home working!
I've downgraded the firmware to v.126 and everything is back to normal, no issues whatsoever now.
To be honest, I don't get how a firmware upgrade can be implemented whereby the programmers manage to break something that worked perfectly well on the previous version.
Anyway, unless there is now a future significant security issue with v.126, I'm not bothering to upgrade the firmware again.
- SigmaOneAspirant
You may want to try V1.0.11.130_10.2.118 which just came out in January 2022.
I also was having problems with the 5GHz dropping on 1.0.11.128. Eventually I went back to 1.0.9.42 because a lot of people suggested it was very stable. Well, 1.0.9.42 didn't drop 5GHz, but it would randomly reboot every 24 hours or so. That's particularly irritating because these r7000's take forever to boot.Anyways, following the upgrade to 1.0.11.130 my 5GHz has been online, and no random reboots for 48 hours now. I'm cautiously optimistic.
- mauryfrenchAspirant
Wow. I just got the same router, here in January of 2022, but it comes with 1.0.11.116 and states that is the latest firmware. So what revision should I get?
