lolcocks
Nov 16, 2019Aspirant
R7000 dropping all static route packets
Hello, I have two routers in my network connected to one another. When I set a static route from my first router (R6400 with DD-WRT) to the second one (R7000 with stock OS), the second router (...
- Nov 18, 2019
I fixed the issue by flashing Xwrt-vortex, a custom firmware that supports NAT from other subnets.
In the end, the culprit was the NETGEAR firmware. There were no issues in routing.
Really disappointed in NETGEAR firmware and it's support.
I won't be buying NETGEAR as my next router.
lolcocks
I was looking at this article:
But I am unable to find any firewall options on the R7000 (latest firmware)
- antinodeNov 16, 2019Guru
> I was looking at this article: [...]
Look on the right side, under "This article applies to:".
I suspect that you have a routing problem, not a firewall problem.
- lolcocksNov 18, 2019Aspirant
antinode wrote:> I was looking at this article: [...]
Hey, antinode
I came across a few old topic of R7000 which say that the R7000 does not support NAT from other subnets.
Such as this topic: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Static-routing-not-able-to-reach-internet/td-p/1122475
Can you please confirm or deny this?
