lolcocks's avatar
lolcocks
R7000 dropping all static route packets
Hello,   I have two routers in my network connected to one another. When I set a static route from my first router (R6400 with DD-WRT) to the second one (R7000 with stock OS), the second router (...
  • lolcocks's avatar
    Nov 18, 2019
    I fixed the issue by flashing Xwrt-vortex, a custom firmware that supports NAT from other subnets.
    In the end, the culprit was the NETGEAR firmware. There were no issues in routing.
    antinode
    Really disappointed in NETGEAR firmware and it's support.
    I won't be buying NETGEAR as my next router.
