rkmase's avatar
rkmase
R7000 dropping randomly - internet and admin unavailable until restart
Firmware: V1.0.6.28_1.1.83 Has been occuring since at least 2 updates ago.   Internet will drop, both wifi and hard wired connections. Admin interface unavailable also. Problem only corrected afte...
  • netwrks's avatar
    Feb 19, 2016
    Internet will drop, both wifi and hard wired connections. Admin interface unavailable also. Problem only corrected after quick reset. Happens randomly, sometimes 2-3 times a day. Thanks for any assistance.
    When you update firmware you should reset your router to factory default..  Also, if you revert to a previous firmware. Reset to factory default and reconfig from scratch.. Always. Do it..
