rkmase
Feb 19, 2016Aspirant
R7000 dropping randomly - internet and admin unavailable until restart
Firmware: V1.0.6.28_1.1.83 Has been occuring since at least 2 updates ago. Internet will drop, both wifi and hard wired connections. Admin interface unavailable also. Problem only corrected afte...
- Feb 19, 2016
rkmase wrote:Firmware: V1.0.6.28_1.1.83
Internet will drop, both wifi and hard wired connections. Admin interface unavailable also. Problem only corrected after quick reset. Happens randomly, sometimes 2-3 times a day. Thanks for any assistance.
When you update firmware you should reset your router to factory default.. Also, if you revert to a previous firmware. Reset to factory default and reconfig from scratch.. Always. Do it..
netwrks
Feb 19, 2016Master
rkmase
Mar 09, 2016Aspirant
One week later and no drops. Fingers crossed it was as easy as a factory reset. Thanks!
