Anonymous
Oct 20, 2020R7000 Dropping WIFI Daily
Hello, I am on the latest software version V1.0.9.88_10.2.88. Over the last 3 days I have been experiencing random dropouts of my WIFI 5g and 2.4g. I went through with inSSIDer and determine ...
- Oct 20, 2020
Your firmware indicates you're on the R7000.
There's 2 firmwares I'd try.
First install the newest firmware which is 1.0.11.110. do it over a hardwired connection and factory reset the router once its updated and then re-install it. don't use a backup.
If that doesn't help, then I'd actually try downgrading to version 1.0.9.42. Its the agreed upon most stable firwmare for the r7000.
you can find the newest firmware here:
Anonymous
Nov 21, 2020Firmware version 1.0.9.42. was the ticket. Zero drops in the last month since I swithched to it. Thanks!
Nov 21, 2020Guru - Experienced User
Glad to hear it helped!
Let us know if you have futher issues.
