nethawkuser's avatar
Nov 19, 2021
R7000 dropping wired more and more frequently over the year, is it dying?
Had this router for quite a while and working really well. Been using 1.0.9.42 for a long time without any issues. But maybe a year ago it first started to slow down. Speed tests show 100-150mpbs when usually I get 900+mbps (1Gbps wired). Rebooting the router fixes it temporarily before it does it again after a few weeks. Then it started to drop internet. The network icon at the bottom keeps switching between disconnected and connected. Again it's fixed after a restart. But it happens more and more often. Now I have to restart it every other day. I tried factory reset but it's the same effect as a restart.
This is getting worse and is it kicking the bucket or anything else I can try? Thanks.
  • You could see if the power supply is going bad. they're a challenge as they'll give the correct voltage until under a load.
    If you have a different power supply with same voltage and polarity, you could try it. The amperage can be different but it still needs to be at least as much as the original.
  • plemans's avatar
    • nethawkuser's avatar
      nethawkuser
      Tutor
      Thanks for the quick reply. I'll try a different power outlet and see if the problem persists. Will something like this work if the adapter is indeed bad?
      • plemans's avatar
        If the power supply is indeed the issue, sure.
        If its not, its a bit of $ down the drain that you could have saved for an upgrade.
        I usually tell people to look around at their current device. You'd be surprised how many use the same voltage/barrel sizes. its just to make sure it has enough amps
      nethawkuser
      Tutor
      Hey so it's been a week and I'm happy to report that my router has been very stable ever since I've switched to a different socket. The fact that you're able to identify the cause so quick really shows how good you are. Really appreciate your help! Glad I asked here.
      • plemans's avatar
        glad you got it back up and running!
