swehjo
Sep 21, 2015Guide
R7000 drops connection
My R7000 drops connection intermittently since a couple of weeks (I t h i n k it started, at least it got worse, after a late upgrade to V1.0.4.30_1.1.67 mid/end of August). It happens one to t...
- May 10, 2016
Just wanted to chime in here, we have a beta firmware that you may all try.
DHodge87
Mar 23, 2016Aspirant
Any update as my now 3 month old R7000 is dropping wan ever few hours but the lan still works
ElaineM
May 10, 2016NETGEAR Employee Retired
- fredgunnMay 18, 2016Aspirant
Does the new firmware resolve the intermittent dropout issue?
My R7000 drops all attached devices once every three weeks or so. Only a reboot resumes connectivity. Sometimes it takes more than 1 reboot. Been using it 1 year on the "67" firmware.
- netwrksMay 18, 2016Master
fredgunn wrote:Does the new firmware resolve the intermittent dropout issue?
Curious, are you using 2.4ghz, or 5ghz? If 2.4ghz, have you selected a channel, for 2.4ghz?
thanks for replying netwrks!
i enable both the 2.4 and 5 radios. a few older devices connect to the former but most of my other devices are on the 5 radio. i use ch 11 for 2.4 and 149+ for the 5. also, both radios are set to a max speed limit of 600mb/s.
i see in this thread that some users have reverted to an even older firmware version and are happy with it?
rgds
fred
