swehjo
Sep 21, 2015Guide
R7000 drops connection
My R7000 drops connection intermittently since a couple of weeks (I t h i n k it started, at least it got worse, after a late upgrade to V1.0.4.30_1.1.67 mid/end of August). It happens one to t...
- May 10, 2016
Just wanted to chime in here, we have a beta firmware that you may all try.
ElaineM
May 10, 2016NETGEAR Employee Retired
fredgunn
May 18, 2016Aspirant
Does the new firmware resolve the intermittent dropout issue?
My R7000 drops all attached devices once every three weeks or so. Only a reboot resumes connectivity. Sometimes it takes more than 1 reboot. Been using it 1 year on the "67" firmware.
- netwrksMay 18, 2016Master
fredgunn wrote:Does the new firmware resolve the intermittent dropout issue?
Curious, are you using 2.4ghz, or 5ghz? If 2.4ghz, have you selected a channel, for 2.4ghz?
- fredgunnMay 18, 2016Aspirant
thanks for replying netwrks!
i enable both the 2.4 and 5 radios. a few older devices connect to the former but most of my other devices are on the 5 radio. i use ch 11 for 2.4 and 149+ for the 5. also, both radios are set to a max speed limit of 600mb/s.
i see in this thread that some users have reverted to an even older firmware version and are happy with it?
rgds
fred
I thought the max on 5ghz is 1300 Mbps..
