swehjo
Sep 21, 2015Guide
R7000 drops connection
My R7000 drops connection intermittently since a couple of weeks (I t h i n k it started, at least it got worse, after a late upgrade to V1.0.4.30_1.1.67 mid/end of August). It happens one to t...
- May 10, 2016
Just wanted to chime in here, we have a beta firmware that you may all try.
swehjo
Oct 04, 2015Guide
Thanks Lucius,
But my problem is not wifi drops, its an "everything drops". Also the cable network...
Lucius1972
Oct 04, 2015Aspirant
That`s bad, tried different LAN IP? I put mine on 192.168.2.x
- swehjoOct 04, 2015Guide
You mean for the router? Sounds a bit off that an IP-address that I've used for the router since new suddenly stops working. Shouldn't be the root cause at least. But if you mean for the equipment I have maybe 10 clients on the network with the same problem, on cable as well as on wifi (in which case the can see the wifi but not connect to it).
- Lucius1972Oct 04, 2015Aspirant
Yes I mean for the router, could be that DHCP does mess things up.
I guess you also factory reset "after" flashing new firmware?
In these cases I power off/unplug the power for my modem and router for 5 minutes, the start my modem first (let it fully startup and configure), then power up my router (R7500).- swehjoOct 05, 2015Guide
Hmmm... well I check that up even if I can't see that as a sudden, new root cause...
And yes, I do reset and power off before and after the new FW and enter the settings manually.
