swehjo
Sep 21, 2015Guide
R7000 drops connection
My R7000 drops connection intermittently since a couple of weeks (I t h i n k it started, at least it got worse, after a late upgrade to V1.0.4.30_1.1.67 mid/end of August). It happens one to t...
- May 10, 2016
Just wanted to chime in here, we have a beta firmware that you may all try.
Mushbeeguy
Oct 08, 2015Aspirant
I have purchased a NEW R700 and it does the same thing. Every 4 hours, like clockwork the WAN port loses conectivity, the light stays white, the IP address is retained, but you cannot ping or connect to anywhere outside the local network. Unit is not overheating( good tip though) and my ISP is at a loss. I opened a case and hope the folks at Negear have an something to tell my ISP. I'm pretty fed up with Netgear's first tier script readers.
swehjo
Oct 08, 2015Guide
"interesting..." I haven't heard anything from support yet. In the meantime I'm investigating the other parts of the network in depth to see if anything is wrong with clients or cabling. The router's behaviour is very random, I cannot find a pattern, finding a root cause. Sometimes it drops when I have this or that cable and/or equipment connected, immediately or after a couple of hours or a day. Sometimes not. As James says, continue the dialogue with them but I would be appreciated if you keep the thread informed
