swehjo
Sep 21, 2015Guide
R7000 drops connection
My R7000 drops connection intermittently since a couple of weeks (I t h i n k it started, at least it got worse, after a late upgrade to V1.0.4.30_1.1.67 mid/end of August). It happens one to t...
- May 10, 2016
Just wanted to chime in here, we have a beta firmware that you may all try.
swehjo
Sep 22, 2015Guide
And I now realize that my 5GHz wifi doesn't work either. Have seen that I couldn't connect to it before, but didn't pay attention to it and just went for the 2,4GHz. But now checking it, none of my Dell PCs or Samsung mobile products can find or connect to it. The admin GUI says that the 5GHz is functioning properly. All green....
Justcrzn
Oct 11, 2015Aspirant
Your laptops don't have the capability for the 5Ghz since they are probably rate for 2.4Ghz only i bought an asus G75 that way and didn't realize it couldn't connect to 5Ghz until I read the network capabilities. You could try buying an external Wi-Fi adapter to plug in just ensure it can receive both 2.4 and 5 Ghz frequencies. Integrated 802.11a/b/g/n/ac will get the job done if you decide to buy a different laptop for the networking capabilities.
- swehjoOct 15, 2015Guide
Laptops, phones and tablets have capability for 5GHz and have connected to that frequency without problems before. So that is unfortunately not the issue.
