Tommyd70454
Jun 05, 2021Aspirant
R7000, drops internet daily
How often do you all complete a factory reset of this router? This thing has been dropping the internet connection daily, sometimes 3 and 4 times. We have been unplgging it, letting it sit for awhile...
Tommyd70454
Firmware: V1.0.11.106_10.2.100
Spectrum modem: Arris TM1602
drop out: both.
The R7000 is hard wired to the computer, not by wifi. When it goes down, we loose internet connection and wifi connections to all devices. But the modems internet icon is steady. I have had Spectrum trouble shoot it remotely and by tech being here. And when the router drops, the modem still gives internet signal.
Jun 05, 2021Guru - Experienced User
I'd try installing the newer firmware.
Its 1.0.11.123
Then do a factory reset and new install. Don't use a backup configuration.
If that doesn't help, try version 1.0.9.42 of the firmware. Again factory reset/new install.
this is the agreed upon fastest/stablest version so far.
