Kage16
May 23, 2016Aspirant
R7000 drops wifi after v1.0.4.28_1.1.64
I've read all of the threads suggesting the factory reset, except it won't reset AT ALL, so please do not suggest that. I've tried the one in the firmware AND the hard reset about 20+ times EACH, nei...
- May 23, 2016
If you are not using the R7000-Arlo feature use this firmware v1.0.5.62.
storm1985
May 23, 2016Prodigy
- Kage16May 24, 2016Aspirant
Trying this, thanks! So far ARLO is gone, so that is a plus. Will see how the wifi connections are from this point on. Also saw the new firmware out there, but I'll let that one burn in for a bit before I jump on it. I learned my lesson of applying new versions too fast.
- storm1985May 24, 2016Prodigy
Kage16 if you have issues with fw v1.0.5.62 you may also upload this newly release latest official fw v1.0.5.64
- IrvSpMay 24, 2016Master
I would get the one just released. It is a real release, not a beta. Since the number was incremented I would assume it has some fixes above the beta level.
