Kage16
May 23, 2016Aspirant
R7000 drops wifi after v1.0.4.28_1.1.64
I've read all of the threads suggesting the factory reset, except it won't reset AT ALL, so please do not suggest that. I've tried the one in the firmware AND the hard reset about 20+ times EACH, nei...
- May 23, 2016
If you are not using the R7000-Arlo feature use this firmware v1.0.5.62.
IrvSp
May 23, 2016Master
Besides loading in the Beta above, which you WILL need to do a RESET (HOLD IN THE BUTTON on the back with a pen or paper clip, until the lights blink) and re-enter your settings.
If you CAN NOT reset with the hidden button in the back, you still can do it via Genie. Log into your router via the browser and on ADVANCED, the ADMINISTRATION tab, you'll see REVERT TO FACTORY DEFAULT SETTINGS, press ERASE, does the same thing. Then once the router re-boots re-enter your settings.
