xrender
Apr 04, 2017Tutor
R7000 Dynamic QoS Throttles LAN transmission
I am surprised and happy to see that the new firmware adds supports Dynamic QoS on R7000. However, it seems that the Dynamic QoS will throttle the local transmission in the LAN network. I have a Samb...
- Apr 06, 2017
The problem is solved after setting my LAN HOME_NET back to 192.168.1.xx (255.255.255.0). Not sure if this is actually a bug or it is my configuration that is improper.
xrender
Apr 05, 2017Tutor
The firmware version is 1.0.7.12_1.2.5
Some additional observation: the upload speed is not throttled exactly at 4.7Mbps. The peak speed could be around 10Mbps but is still far below the speed without QoS (15~20MB/s)
I simply transfer the large file using ordinary Windows 10 file sharing protocol (both my client computer and file server run Win10). Both the server and the client are at 10.0.0.xx in the LAN
Apr 05, 2017Guru - Experienced User
Can you connect a external Gb network switch between the PC and the Server and test? Connect one port of the switch to the router.
- xrenderApr 05, 2017Tutor
I'd be happy to help reproduce the issue/change settings and test if it is feasible, but I currently don't have extra Gb switch available...
I suspect if it is because of my HOME_NET setting (10.0.0.xx). I have all devices statically binded to some address so changing them will be painful.. I will have a try if possible.
Additional info: my server is connected wired (Gbs connection), and my client is connected through netgear A6200 AC adapter, with the actual connection rate at 400~800 Mbps
- FURRYe38Apr 05, 2017Guru - Experienced User
I would try the client PC with a direct LAN wired cable as well.
Try a Gb network switch when you get the opportunity.
- xrenderApr 06, 2017Tutor
