xrender
Apr 04, 2017Tutor
R7000 Dynamic QoS Throttles LAN transmission
I am surprised and happy to see that the new firmware adds supports Dynamic QoS on R7000. However, it seems that the Dynamic QoS will throttle the local transmission in the LAN network. I have a Samb...
- Apr 06, 2017
The problem is solved after setting my LAN HOME_NET back to 192.168.1.xx (255.255.255.0). Not sure if this is actually a bug or it is my configuration that is improper.
Apr 05, 2017Guru - Experienced User
I would try the client PC with a direct LAN wired cable as well.
Try a Gb network switch when you get the opportunity.
xrender
Apr 06, 2017Tutor
