IrvSp
Nov 06, 2016Master
R7000 email not sent at correct time after daylight savings ended, F/W 1.0.7
My log came in one hour early today (Sunday Nov. 6th) and daylight savings time has ended early this morning on the East Coast of the US. From the LOG still on the router: [email sent to: icc...
- Nov 07, 2016
@searay wrote:I did Nothing and today it arrived at 7am on time.
Mine too. Who knows why, probably an internal s/w flag didn't get properly set until the next time sync which happened well after I posted according to my log.
IrvSp
Nov 06, 2016Master
I suspect that a re-boot will be required. Obviously the router has the correct time.
It may not though? Suspect the mailing time was set using the DST setting at the time and it was internally set to 6AM during DST and added 1 hour as DST was set internally. Now when that flag was removed it sent it at 6AM but didn't account for the flag being turned off. Never set the time internally to 7AM but probably would have worked for some if it was set when DST flag was not on as it would have been handled properly. Pure speculation but if true then a reboot will not fix it either. Only a resetting of the mail delivery time, change it to something else and then reset it to the time you want. However, if this IS true, then the problem will re-appear next spring.
Retired_Member
Nov 07, 2016I did Nothing and today it arrived at 7am on time.
- IrvSpNov 07, 2016Master
- Retired_MemberNov 07, 2016
If that's the biggest problem Netgear had they'd be doing great.
