Nav1x1
Aug 23, 2016Aspirant
R7000 Enable Wifi on Schedule
Hi All, I am trying to setup wifi on schedule so that my kids don't have access to Internet when they need to doing their homework. I have setup the schdule, but it DOES NOT TURN ON by it se...
- Nov 22, 2016
Hi Timmer66,
I can see that option in my the advanced wireless setup.
"Enable Wireless Router Radio"
JamesGL
Community Team
netwrks
Aug 23, 2016Master
If you want to do it on the fly you can turn the wifi_ off manually - Page11 or disable radios - page 110. Wireless schedule - page 110.
- Nav1x1Aug 23, 2016Aspirant
Yes, I am able to do it,
but how to do it on the schedule?
Is this a bug that needs to be fixed or is there a work around for it?
I don't want to be around switching the wifi on and off.
appreciate any insight..
- AnonymousAug 23, 2016
the Turn off schedule settings should start with Time OFF and then Time ON..................If the button was set to off on top right side of router then nothing will turn wifi on again until it's pushed again.
I have my wifi on at 2.4 GHz
I am trying to do the schedule off this with 5 GHz
So in some ways the router is switched on and working. Any pointer will be nice
- Timmer66Nov 13, 2016Aspirant
Hello. I looked on page 110 of the manual and it shows a check box to enable wireless radio. When I go to that advanced page on my router, there is no longer any option to turn that off. I also used to be able to from my Iphone. I would turn it off when I wanted the kids off if they didnt listen to me, and I would just kill it from my phone, even in bed. I cannot find any such option any more, from my phone or my desktop computer.
I am running the latest version V1.0.7.2_1.1.93. This has been a bit frustrating. It was a nice tool that was suddenly gone. Any direction towards finding how to do this again would be much appreciated.
- JamesGLNov 14, 2016NETGEAR Employee Retired
Hi Timmer66,
Please check page 132 of the user manual.
http://www.downloads.netgear.com/files/GDC/R7000/R7000_UM.pdf?cid=wmt_netgear_organic
JamesGL
Community Team
- Timmer66Nov 16, 2016Aspirant
The option shown is no longer available with the latest firmware update I installed.
