Nav1x1
Aug 23, 2016Aspirant
R7000 Enable Wifi on Schedule
Hi All, I am trying to setup wifi on schedule so that my kids don't have access to Internet when they need to doing their homework. I have setup the schdule, but it DOES NOT TURN ON by it se...
- Nov 22, 2016
Hi Timmer66,
I can see that option in my the advanced wireless setup.
"Enable Wireless Router Radio"
JamesGL
Community Team
netwrks
Aug 23, 2016Master
If you want to do it on the fly you can turn the wifi_ off manually - Page11 or disable radios - page 110. Wireless schedule - page 110.
Nav1x1
Yes, I am able to do it,
but how to do it on the schedule?
Is this a bug that needs to be fixed or is there a work around for it?
I don't want to be around switching the wifi on and off.
appreciate any insight..
- Retired_MemberAug 23, 2016
the Turn off schedule settings should start with Time OFF and then Time ON..................If the button was set to off on top right side of router then nothing will turn wifi on again until it's pushed again.
- Nav1x1Aug 23, 2016Aspirant
I have my wifi on at 2.4 GHz
I am trying to do the schedule off this with 5 GHz
So in some ways the router is switched on and working. Any pointer will be nice
Have you looked at the manual yet?
You were given several suggestions in your initial response?
Are you expecting someone to read it to you?
I have some free time this afternoon, What's your phone number?
