Psychbum
Apr 20, 2022Star
R7000 ethernet devices missing
Not sure when this started happening but when I go into the web GUI of the R7000 and attached devices all my wireless clients are displayed. But, my ethernet devices are not - the router status light...
Apr 20, 2022Guru - Experienced User
I don't thing the .134 (latest) version changed attached devices but you can try upgrading to it.
https://www.netgear.com/support/product/r7000.aspx
if it doesn't help, you can try factory resetting.
- PsychbumApr 20, 2022Star
I tried going to .134 but it was very bad.
So I am back to .130 but suddenly my ethernet devices aren't staying connected.
They seem to be connected but when in sleep the devices leave the network instead of staying connected.
- plemansApr 20, 2022Guru - Experienced User
Did you do a factory reset after the changes? the R7000 has responded pretty favorably to resetting after changing firmware. I'd advise during the reinstall to not use a backup configuration
Yes, I actually ended up doing 2 factory reboots and its still the same. So cant see the point in another.
- johnsmith5Apr 20, 2022Aspirant
plemans wrote:I don't thing the .134 (latest) version changed attached devices but you can try upgrading to it.
yeah, i have tried it but it was not helpful for me so there was only one option that was factory resetting i do this and got.
I have managed to get the .134 FW installed and seems stable.
I removed a meross smart plug that i added into the mix a few days ago and the ethernet devices are staying connected.
Anybody know why this type of device would cause the ethernet devices to stop functioning?
Thanks
- FURRYe38Apr 20, 2022Guru - Experienced User
What browser are you using?
