Psychbum
Apr 20, 2022Star
R7000 ethernet devices missing
Not sure when this started happening but when I go into the web GUI of the R7000 and attached devices all my wireless clients are displayed. But, my ethernet devices are not - the router status light...
Apr 20, 2022Guru - Experienced User
Did you do a factory reset after the changes? the R7000 has responded pretty favorably to resetting after changing firmware. I'd advise during the reinstall to not use a backup configuration
Psychbum
Apr 20, 2022Star
Yes, I actually ended up doing 2 factory reboots and its still the same. So cant see the point in another.
- plemansApr 20, 2022Guru - Experienced User
sorry, didn't know if you did or not.
the version thats been the most stable is pretty old. The one we always used to recommend was 1.0.9.42
The .126 version was also fairly stable for those devices it worked well on.
It seems like there's a small percentage of the r7000's that struggle with firmware
- PsychbumApr 20, 2022Star
Obviously I want to avoid going too far back for security concerns.
What would be your advice here? Which version?
so they don't show up in the attached devices list. Do they show in the access control list (doesn't have to be enabled).
If they do, I'd just leave it as is.
If they don't, then I'd try downgrading
