Psychbum
Apr 20, 2022Star
R7000 ethernet devices missing
Not sure when this started happening but when I go into the web GUI of the R7000 and attached devices all my wireless clients are displayed. But, my ethernet devices are not - the router status light...
Apr 20, 2022Guru - Experienced User
so they don't show up in the attached devices list. Do they show in the access control list (doesn't have to be enabled).
If they do, I'd just leave it as is.
If they don't, then I'd try downgrading
Psychbum
Apr 20, 2022Star
It is connected as I am using it, but the GUI doesn't show its connected.
It is using the IP address 192.168.x.11 and a smart switch I have is on 2.4g wifi and using 192.168.x.11
How do I change this? And could this be the cause?
