Psychbum
Apr 20, 2022Star
R7000 ethernet devices missing
Not sure when this started happening but when I go into the web GUI of the R7000 and attached devices all my wireless clients are displayed. But, my ethernet devices are not - the router status light...
johnsmith5
Apr 20, 2022Aspirant
plemans wrote:I don't thing the .134 (latest) version changed attached devices but you can try upgrading to it.
https://www.netgear.com/support/product/r7000.aspx
if it doesn't help, you can try factory resetting.
yeah, i have tried it but it was not helpful for me so there was only one option that was factory resetting i do this and got.
Psychbum
Apr 20, 2022Star
I have managed to get the .134 FW installed and seems stable.
I removed a meross smart plug that i added into the mix a few days ago and the ethernet devices are staying connected.
Anybody know why this type of device would cause the ethernet devices to stop functioning?
Thanks
