BigRed0287's avatar
Feb 12, 2017
R7000 extremely slow upload speeds
I recently purchased my Nighthawk AC1900 (R7000) and have been having issues with the upload speeds. I've edited QOS and restored to facotry settings. Yet, the problem still persists.
  • LeeH's avatar
    LeeH
    Feb 12, 2017
    Make your changes to the configuration slowly one at a time making speed checks between each change.
    You won't ever need QOS with the speed of your Internet connection.  Don't even turn it on because I have seen it give people problems like you had even after turning it back off.
    Don't ever upgrade firmware unless it fixes a problem you are experiencing or it has a security fix you need.  I kept my R7000 on 1.0.4.28 until 1.0.7.6 came out with security fixes.  Every firmware change is a risk of corrupting or even bricking your router.
