BigRed0287
Feb 12, 2017Tutor
R7000 extremely slow upload speeds
I recently purchased my Nighthawk AC1900 (R7000) and have been having issues with the upload speeds. I've edited QOS and restored to facotry settings. Yet, the problem still persists.
- Feb 12, 2017
Make your changes to the configuration slowly one at a time making speed checks between each change.
You won't ever need QOS with the speed of your Internet connection. Don't even turn it on because I have seen it give people problems like you had even after turning it back off.
Don't ever upgrade firmware unless it fixes a problem you are experiencing or it has a security fix you need. I kept my R7000 on 1.0.4.28 until 1.0.7.6 came out with security fixes. Every firmware change is a risk of corrupting or even bricking your router.
BigRed0287
Feb 12, 2017Tutor
After resetting and leaving SSID as provided, upload speed is back in the 30's. Do i have to keep the provided SSID that came with the router or can i change it now that the upload speed is back to normal?
LeeH
Feb 12, 2017Prodigy
- BigRed0287Feb 12, 2017Tutor
Thanks for the help
