mcloaked
Jan 01, 2016Tutor
R7000 fails to update GUI Language version
I have just updated my R7000 to new firmware using the firmware update facility on the embedded web interface to version V1.0.6.28_1.1.83 and that worked fine. After the router restarted I checked f...
- Jan 05, 2016
Hi All,
Thank you for the feedback. Glad it works now.
Retired_Member
Jan 01, 2016Download the Zip file from support extract it and then reload it.
- mcloakedJan 02, 2016Tutor
Thanks for the reply - can you point me to a link to get the zip file? Also is the zip file for the same firmware as well as the gui language update or just the gui language update?
- randomnut1Jan 02, 2016Apprentice
I'm also getting this. Tried also updating by downloading the firmware zip file and it also coninually says there is an updated language file available but fails to update.
- mtg1974Jan 02, 2016Initiate
I assumed that you meant the firmware update zip file. I downloaded it and upgraded my router but there is still a language update.
- thelemonkidJan 03, 2016Luminary
Same issue!!!
- Retired_MemberJan 03, 2016
When NG released the update, the automatic update process was hosed, my guess from being overloaded with update request, SO I downloaded from support and manually updated without a problem.
I would revert to a earlier version and try again. If the automatic is slow again, download from support. extract and manually update. Make no mistake these last several updates require a factory default so get over it.
