mcloaked
Jan 01, 2016Tutor
R7000 fails to update GUI Language version
I have just updated my R7000 to new firmware using the firmware update facility on the embedded web interface to version V1.0.6.28_1.1.83 and that worked fine. After the router restarted I checked f...
- Jan 05, 2016
Hi All,
Thank you for the feedback. Glad it works now.
mcloaked
Jan 02, 2016Tutor
Thanks for the reply - can you point me to a link to get the zip file? Also is the zip file for the same firmware as well as the gui language update or just the gui language update?
randomnut1
Jan 02, 2016Apprentice
I'm also getting this. Tried also updating by downloading the firmware zip file and it also coninually says there is an updated language file available but fails to update.
