mcloaked
Jan 01, 2016Tutor
R7000 fails to update GUI Language version
I have just updated my R7000 to new firmware using the firmware update facility on the embedded web interface to version V1.0.6.28_1.1.83 and that worked fine. After the router restarted I checked f...
- Jan 05, 2016
Hi All,
Thank you for the feedback. Glad it works now.
Retired_Member
Jan 01, 2016Download the Zip file from support extract it and then reload it.
mtg1974
Jan 02, 2016Initiate
I assumed that you meant the firmware update zip file. I downloaded it and upgraded my router but there is still a language update.
- thelemonkidJan 03, 2016Luminary
Same issue!!!
- Retired_MemberJan 03, 2016
When NG released the update, the automatic update process was hosed, my guess from being overloaded with update request, SO I downloaded from support and manually updated without a problem.
I would revert to a earlier version and try again. If the automatic is slow again, download from support. extract and manually update. Make no mistake these last several updates require a factory default so get over it.
